I own a StudioLive AR12c that I use as my audio interface into the DAW (Studio One). I am currently considering buying some outboard gear for tracking (preamp + comp).
As a result, I am also looking into ways I could then use the same outboard gear during mixing or to route VST instruments through the gear (in stereo). => As far as I can tell, that will not work with this StudioLive (due to the missing Aux In / Outs to insert PipelineXT into the chain)? The only thing I can come up with when looking at the block diagram (e.g. for a simple re-record of a single stereo VST instrument track from the DAW): DAW => Digital Return 3/4 => Solo PFL Fader 11/12 => Control Room => Outboard Gear => Back to DAW via Stereo Channel 9/10 But of course that would only work for a single dedicated DAW track at a time. => Is that indeed the only option or am I overlooking something? |
Hi and welcome to this forum
I think you got it right. The limiting factor is the number of returns the AR mixers offer: only two stereo channels. With some hard thinking that could give you 4 mono channels from your DAW, to outboard gear, for 4 (stereo if you want or outboard gear needs) sends back to the DAW. But probably you want to reserve one of the two stereo returns for listening to what you're doing while you're doing it. PS. Note that the analog input sends from channel 11/12 to the computer still work even if you switched the channel to usb input. |
SwitchBack wroteHi and welcome to this forumThanks SwitchBack wroteI think you got it right. The limiting factor is the number of returns the AR mixers offer: only two stereo channels. With some hard thinking that could give you 4 mono channels from your DAW, to outboard gear, for 4 (stereo if you want or outboard gear needs) sends back to the DAW. But probably you want to reserve one of the two stereo returns for listening to what you're doing while you're doing it.Yes, Digital Return 1/2 is already blocked for the main mix out of the DAW. SwitchBack wrotePS. Note that the analog input sends from channel 11/12 to the computer still work even if you switched the channel to usb input.You mean I could use them as the Digital Return from the DAW and then route the returned signal from my outboard gear via the same channel 11/12 back to the DAW? I haven't tested that yet, but the manual states the following which made me believe that this would not work : When a digital return is engaged, it replaces the analog input in the mix.But upon reading it again, it says "mix" and not "Digital Send". Overall: I had chosen the StudioLive AR originally because I wanted:
Back then the topic of requiring outputs was not on my horizon . Looking at StudioLive 16.0.2 USB, that would resolve the issue somewhat, since that has 16 digital outs but still again only a few physical outs (4 x Aux and Control Room) to connect to outboard gear. Would also loose the Bluetooth, but there are other ways to handle that. Plus there the onboard processing (EQ, comp, etc.) can actually be used for DAW tracking. Or alternatively I would need another audio interface which I use as bridge to the DAW and would need to split all signals via a patchbay before that to duplicate them for the StudioLive as room control. But that doesn't sound clean either... I guess my approach is probably a weird combo of not needing that many channels in parallel for DAW tracking (two at most), but needing/wanting at least 12 channels to have all instruments ready for practicing all the time with easy volume control and playbacks |
Well, IMHO nowadays outboard gear is overrated for use in combination with audio from a DAW*. For the price of one hardware LA-2A you can buy a brilliant plug-in of it (for use on as many signals as you like) and 10 others. So unless you have an all analog studio or at least a high quality analog mixing console to use with that outboard gear you're probably better off by keeping the signal and the processing inside your DAW.
* Recording instruments and microphones is a different story, but that doesn't require interface outputs, just inputs. |
Yes, in-the-box will remain the main approach. But since for the tracking part I am considering some outboard gear to play around with (not in the price range of a real UA LA-2A though ), the question reg. the routing options to also use it for mixing popped into my head.
Thanks for confirming that my understanding of my options with the StudioLive AR were (unfortunately ) correct. |
