I have a Studiolive AR12 USB going into a Mac Pro and using Logic Pro X as DAW. I have a Blue Mic Bluebird connected to AR12 through XLR and have to crank the input on the AR12 just to hear anything through Logic Pro. What gives?
by sjc193 on Tue Apr 11, 2017 5:35 pm
Does that mic need phantom power?
Are you recording the channel input pre everything? So the signal is clean before the eq and fader or anything else.
Or are you record the main left and right out? Not really recommended in a studio environment
Just asking for some more input on the workflow.
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
4 EV ZLX-12P's, 2 Yamaha S115V's
4 Behringer EP2500 amps, 1 QSC Amp
10 58/57 mics, 1 AT2020, 2 AT2021, 1 beta52 kick mic
2 e609, 2 Radial J48 DI's
cron
