Hello,
Just taken delivery of an AR12. Recording a simple mix onto the SDHC card seems fine, except that when playing back there is a huge amount of hiss. Any suggestions? With thanks, Toby |
This issue is also being discussed here where two other users are reporting the same problem:
http://answers.presonus.com/11651/hiss-on-sd-card-recordings?show=11658#a11658 |
Just spent several hours with our lovely dealer trying three different AR12's recording onto two different SD cards. Sadly all of them exhibited the hiss on the SD card recording. Design fault maybe?
Tobyc, 1moderntalking1, congratulations on your purchase! Please open a support ticket with tech support so we can help you get sorted out. To do so, click on the hyperlink in my signature. After you receive a ticket number, also PM (private message) me the ticket number for reference.
Also, would you create or modify your signature to include your system specs? This helps to expedite the process and reduce the number of questions that have to be asked going forward. To create or modify your signature click on the appropriate hyperlink in my signature. Regards, Skip
Skip
Hi all:
The SD recording is Post-main fader. So if you have a low input signal and your main fader set low as well, you're not going to achieve a good signal-to-noise ratio on your SD recording. I've posted a knowledge base article with instructions here: http://answers.presonus.com/12955/why-i ... ding-noisy Hope this helps!! -W |
Thanks Wesley! #IamStudioLive http://www.presonus.com/videos/player#IAmStudioLive-Wesley
Regards
Skip
