I know that Studiolive AR16 is capable of recording individual mixer channels via USB but can it be also used as a low latency USB audio interface? What I have in mind is to get rid of my 8input audio interface and use solely the AR16 as a main audio interface. Does anyone know what the latency is going to be? And also If I connect the AR16 to a computer, what will I hear coming from the main outputs (or Control room outputs) of AR16 - a raw signal from mixer inputs or a processed by VST plugins signal? |
I have been recording and mixing through my AR16 for about a month now, as well as recording live band rehearsals and jam sessions. My previous DAW interface was a MOTU Ultralite Mk2 that died. The AR16 has been a very capable audio interface to date via the USB 2.0 interface.
When I'm mixing audio, I set my block size to 1024 or 2048 and can pile on the effects. The thing is that anything recorded directly into the AR16 (like layering another guitar, bass, or vocal) is processed in 0 latency real time on the mixer, so you don't need it to go to Studio one and return before hearing it. The mixer has a ton of processing power for each channel strip. The USB return allows 4 incoming channels from the DAW, though I'm just usually returning the processed mains. When I record with my MIDI interfaces, I switch the block size to 128 to get low latency. To avoid cracking and popping during music production over USB devices that need to route through the computer first, through Studio One, into the AR16 USB channel strip and out to the speakers, I'll turn off heavy plugins like iZotope Ozone or any heavy pulse wave reverb plugins that are on the master bus. Of course, when you are doing heavy electronic music production and have a ton of plugins running, you often need to start freezing tracks or exporting mixdowns to other tracks anyway but that's a CPU power limitation and not the audio interface. I haven't pushed the mixer into 100+ tracks of effects processef audio, but it has been really responsive for my needs so far. I hope this helps. |
patrickwickline wroteI'd also like to use the AR16 as my main audio interface. It's 0 latency. When you plug headphones into the headphone jack, anything routing through the mixer is heared in real-time. One thing I haven't figured out yet is how to light up the headphone jack in Studio One as a separate output from the mains bus. I don't know if that's possible. The 16/17 strip is the USB return and it controls the levels coming in from USB (or Bluetooth). This affects USB volume within the entire mix, and the headphones are playing anything coming into the mixer as soon as it arrives - no latency waiting for a round trip through the computer. |
donaldhampton1 wroteThe AR16 has a serious problem on the digital channel that Presonus will not acknowledge and apparently has no fix for. My board has been back to them three different times and nothing has changed. I would not recommend this board if you care about using the digital channel. Unless you describe the nature of the problem this isn’t very informative. And you would not be the first to expect more than a product was designed for. |
avaktar wrotepatrickwickline wroteI'd also like to use the AR16 as my main audio interface. Zero latency is relevant for audio interfaces where the only way to get a signal from input to output is through the computer attached. (The trick used is to have the driver route the inputs back to the outputs, bypassing any other software running on the computer). Mixers (including the ARs) have their own internal routing from inputs to outputs, so no need for tricks. As for routing a separate signal from computer to mixer headphones: that will cost you channels 15/16 in your mix. Pressing the USB button on channel 15/16 will put USB return channels 3+4 on mixer channels 15/16. Together with USB return channels 1+2 on mixer channels 17/18 that gives you two stereo returns to work with. Note that the mixer’s analog inputs 15/16 will still go to the computer, for recording and DAW processing. You could even return the signal to the mixer, even though that introduces a little bit of latency |
SwitchBack wrotedonaldhampton1 wroteThe AR16 has a serious problem on the digital channel that Presonus will not acknowledge and apparently has no fix for. My board has been back to them three different times and nothing has changed. I would not recommend this board if you care about using the digital channel. I too am having USB issues. Had this unit for 5 days now. Purchased specifically to use as a live audio interface. I cannot monitor via the AR16c. Using 3 different Windows 10 PCs I have very unreliable connections. I can see the AR16C on the windows audio link, most times on the Universal Control link but it is not recognized by Studio One. I can sometimes get connected to Cubase on one of my laptops but across the board (no pun intended) I can not monitor via the AR16c. Exception- once. I got the system to work for about 10 measures in a cubase project (4 tracks with no plugins) before it disconnected. I have a ticket open with Presonus and have had one support session with the seller tech support and another upcoming tomorrow. |
Hi and welcome to these forums
If you read my previous post then you know that the AR16 does not need a computer at all to provide you with Aux1/Aux2 monitor mixes. There's no latency on these mixes because the signal path is all analog. And even if the computer crashes the monitor mixes will still be there, effects and all. The usb connection allows you to record mixer channels 1-16 and the mixer's main mix, completely independent from the mixer's local operation. The usb connection also allows you to return two stereo channels to the mixer, to channels 17/18 and 15/16. This of course needs a working usb connection. And returning a live mixer channel via the computer back to the mixer will of course introduce latency, so don't. |
charlesperry5 wroteSwitchBack wrotedonaldhampton1 wroteThe AR16 has a serious problem on the digital channel that Presonus will not acknowledge and apparently has no fix for. My board has been back to them three different times and nothing has changed. I would not recommend this board if you care about using the digital channel. Well, turns out my USB card was faulty right out of the box. Excange in progress. |
charlesperry5 wrotecharlesperry5 wrote How did the exchange go? I'm having what sounds like the same issue with my AR16c! The first one I got worked for about 2 minutes at a time before crashing in Capture, and then no computer could find it again (reinstalled Universal Control on a Mac, 3 different PCs, and a linux machine for kicks, none would recognize the mixer) So I sent that back and they quickly replaced and the new worked well and got some good drum recording in! (15 tracks simultaneously) Now the previously working one is not seen in Universal Control again on the computer I did the recording on a few weeks ago. Reinstalled drivers, UC, reboot computer, turn on off mixer, disconnect/reconnect, etc, still no dice! One thing I notice is that the USB-C connector on the back is very shallow, for some reason will only allow the cable to plug in about 60% of normal. Both mixers I've had were like this, but seems very odd and could be a likely culprit, especially if you mention a faulty USB card. How does everyone else's plug work? Did I get a strange one, or has Presonus intentionally used a non-standard USB-C? |
I am also having issues with interface to USB. Put my ticket in today. Great analogue mixer....not so good at audio interface for recording. 2 days old and no recordings yet....keeps quitting. Tried 2.0 and 3.0 USB also. You're right about the fit of the USB C on the board...strange it doesn't go in on mine either. Got this to replace my faulty 1818VSL.
