New to this kind of stuff. I want to record all channels from mixer (AR16) into capture which I figured out how to do. But is there a way to only have certain channels in the main output/speakers? I was thinking making an aux mix and sending them through speakers but not sure if that works, or if there is another way to do it. Sorry if question seems lame, I'm new to mixing/sound. Thanks for any help.
Record/usb 'send' is the signal going to the computer via usb.
The trim knob (channel gain) sets the channel input level and the usb send level. The usb send comes after the low cut button so that also affects the signal to the computer. But channel EQ and the channel fader come after the usb send so have no influence on the signal to the computer. |
The usb sends are always engaged. There's a button for sending main via usb sends 1&2 but then you can't record the input on channels 1 and 2 anymore. Only use that button if you must.
The AR mixers have two buttons for the two usb stereo returns, one on the SuperChannel and one on the channel next to it. But these buttons have no effect on the usb sends. |
