Hello,
Would it in principal hurt the V-Fire interface if one would use both FireWire power as well as the net adapter power simultaneously ?
Thanks.
Richard
by cristofe on Mon Dec 07, 2015 12:32 pm
It shouldn't....but why would you need/want to? BTW....we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix".
by richardwedding on Mon Dec 07, 2015 1:22 pm
Thanks Christofe for your kind response.
You are absolutely right that one just can't have enough relevant background information when it comes down to technical support situations.
For now I just would like to know whether or not in principal one can apply both FireWire power as well as net adapter power to the V-Fire interface in particular, without overloading or damaging the device.
Thanks again,
Richard
by Karyn on Wed Dec 09, 2015 7:27 am
Should not hurt it in principal.
Karyn
Sonar Platinum, Studio One.
http://refer.waves.com/dzDVn
Dante Level2 certified.
by richardwedding on Thu Dec 10, 2015 5:35 am
Thanks for your response Karyn.
Richard
