Is the SW5E AVB box compatible with RM32AI and CS18AI mixer and control surface ?
Yes, check out this article.
Both switches "speak" AVB I and AVB II, but only the MOTU AVB switch has a dedicated output for a router. Which you will need for the AI mixers, because AVB and Remote Control is using the same port. Thinking about future developments, you don't necessarily need a SWE5 AVB switch. All Series III mixers have separate ports for AVB and Control, so a 32-channel or 48-channel combination of FOH mixer and "stagebox" (rack mixer or NSB stagebox) does not need an AVB switch. Save your money for the future...
