CS18Ai Control Surface 'TALKBACK ISSUE'
Posted: Fri Jan 18, 2019 7:37 pm
by marlo_haboc
I updated my CS18AI firmware to the latest, i can't unmute the talkback on all mixout, i can only use it on main out.... anyone knows how to solve this? thanks...
Re: CS18Ai Control Surface 'TALKBACK ISSUE'
Posted: Sat Jan 19, 2019 10:41 am
by wahlerstudios
I have already forgotten things from my CS/RM "era", but I think I remember that this was changed lately. If you will, the "Mute" is now the "Talk" button on the CS18. You press the button when you want to use Talkback, otherwise the microphone is muted or simply off. You need to assign the outputs you want to talk to. There is a menue for this functionality. It makes sense to organize it this way, also because the Series III mixers work like this.
Please do NOT update the firmware of a RM mixer. You will get some problems. The new firmware for the CS18 is ok and both version work fine together.
