I am curious that is possible to control any other mixer like soundcraft ui or behringer sd16 with c18ai? If is possible, my question is that can i use fat channel effects with them? cheers! |
No, as the product page says the CS18AI is the "Control Surface for StudioLive RM Mixers and Studio One DAW". The CS18 is not meant to work with other products, also not within the PreSonus families of mixers. The CS18AI is a controller, not a mixer. All processing (e.g. fat channel) is done on the RM rack mixers.
The RM/RML mixers are often considered as "digital stageboxes", but they are not. They can be used in two stagebox modes with the SL AI mixers, which can make the terms unclear. The RM/RML products are 32 channel mixers with 16 flex mixes and 3 main mixes. You can see the CS18AI as UC Surface with knobs and (motorized) faders, but it is much more... Here is more to read about the CS18 and the up to 64 channels expandable "StudioLive AVB Systems": https://www.presonus.com/products/StudioLive-CS-Series. |
