I have a problem with our cs18ai control surface, it doesn't sync with the rm32ai mixer, we have been using it for a few months now, this is the first time that we encounter this problem, try to restart both, change the cat5e cable.... it doesn't seems to solve the problem.... can any have encounter the same trouble and solve it?
If you're using a direct connection, fixed IP addresses are needed. It looks like they have got mixed up.
Quote from http://www-media-presonus.netdna-ssl.com/downloads/products/pdf/StudioLiveAI_and_RM_Family_1.5_ReleaseAddendum.pdf "Static Selfassigned IP Mode: This mode is used primarily for when you’re setting up a direct ethernet connection between the mixer and another device like an AI Console mixer or CS18AI, but without the use of a router. In this mode the mixer will automatically assign itself an IP Address in the 169.254.0.0/16 range, allowing connection with other devices in the same IP address range." |
