The following was compiled by a fellow member themuzic (aka Johnny Geib). Johhny also runs the Home Studio Trainer website (homestudiotrainer.com), providing one/one training for Studio One and other presonus products.
This list should be considered "Un-Official", as it was not compiled by Presonus directly. There may/may not be features not listed here. We will try our best to keep this updated as things are added/deleted from the feature set. I am also attaching a text doc of the same listing for download. CS18 WORKING FEATURES: Faders, Mute, Solo, Select, Pan Faders control DAW faders Busses are in “Mix Masters” FX Busses are in “Returns” “Mute” mutes DAW channels “Solo” solos DAW channels Pan is controlled by 16 encoder knobs at the top and can also be controlled by encoder under the Touchscreen for currently selected track. Select button color matches Studio One channel color Track Channel Mode (mono\stereo) Selecting a track and then clicking the Stereo "Link" button will change the channel mode between mono and stereo. Scribble strip Shows: channel name Automation mode Pan Control Link parameter for Plugins Record arm Hold "Option" and press channel "Select" to toggle record arm on/off per channel. When in record arm the scribble strip will display a large "R" to indicate an armed channel Channel layer navigation Channels 1-16, 17-32, and so on. Press Shift and channel layer to go to channels 65-128. Press CTRL and channel layer to go to channels 129-192. (Not implemented) Groups button used for mixer "scenes". Select a scene to hide channels not in the scene. Option to add a scene/group, page to show selected group with exit and delete buttons. FX/Aux Returns button show FX channels Mix Masters button shows buses Group Masters button shows output channels Group Masters Button (under fader selectors) Any Cue mixes created in Studio One can be controlled, independently, by a fader when the "Group Masters" button is selected. (This is only active when the output in the Studio One Output matrix has the "Cue" box checked) Flex Fader Pressing “Edit” in “Assign” section will assign currently selected channel to the Flex Fader Deselecting and pressing "Edit" again will release the Flex Fader. This will also work with tracks that are grouped together in Studio One. Mix navigation Press Main Mix button to have the main L/R mix on faders Press Mix button 1 - 8 once to bring the associated send mix to the faders. Mix number corresponds with Send slot numbering from top to bottom Press Mix button 9 - 16 once to bring the associated cue mix to the faders. Mix number 9 - 16 corresponds with Cue Mix slot from top to bottom Automation modes Uses Mute group buttons. All On = All Read 1 = Read 2 = Touch 3 = Latch 4 = Write 5 = All Read 6 = All Touch 7 = All Latch 8 = none Transport Uses Transport buttons as labeled Modifiers for additional funcitons “Option” engaged - Stop is “Fast Forward;” RTZ is “Rewind” “Ctrl” engaged - Stop is “Next Marker;” RTZ is “Prev Marker” Solo clear Clear and channels that are “Solo” enabled FX Inserts/Sends Tapping FX on Touchscreen opens list of Inserts or Sends for selected channel Inserts - shows top down list of plugins on channel Sends - shows top down list of sends on channel Tapping plugin in Inserts list will map plugin parameters to 16 encoders Parameter names show in 16 mini screens per channel Parameter value shows in Touchscreen and via meter bridge Tapping again dismisses plugin from computer screen and unlinks plugin parameters from encoders Tapping Sends will select it. Send level controlled by encoder below touchscreen Jog Function The knob under the touch screen can be used as a "Jog" when enabled from the Markers button and then hitting "JOG" at the top of the screen. Control Link Mode De-activating all buttons to the left of the "Selected Channel" meters, activates the Fat Channel for Control Link assigning of the knobs and buttons. Foot Switch Make sure the CS18 is in DAW mode Select "System" Now go to Footswitch Mode Press it and you will now see a drop down If you can not see the DAW options, select the last option and then select again. You will now see 2 DAW options "DAW Rec/Start" and "DAW Drop Markers" Select the one you need and then press home.
Footswitch still not working ??
I have a footswitch with normally open switch plugged in the fooswitch-chassis, and it doesn't do any thing hen my CS18 is connected to my mac pro with studio One pro (latest version) i see the dropdown menu when in DAWmode. i selected normally open, then i pushed Home... but when i'm in a songfile and wanna record (in recordmode), my footswitch does not function. the footswitch works on other gear. What's up ??
Senior audio-engineer @ WWW.LGS.NL for live audio, recording and studio productions in the Netherlands and abroad.
Anyone on the foot-switch issue ??
No sorry not using this feature
George Ware
StudioOne v4.5.5 Pro 64bit Waves DigiGrid IOS Waves DigiGrid IOX Waves SoundGrid Server One PreSonus CS18ai & BCR2000 Control Surface Intel 6 Core i7 3.2Ghz. Windows 10 Professional 64bit. v1909 Arturia KeyLab-88 Essential URS, Waves (Everything), EMI, Sonnox Oxford (Everything), Antares, Plugin Alliance (Everything), Nomad Factory,TL Labs, Massey, Komplete Ultimate 12 CE, Arturia (Everything), Lounge Lizard 4, Korg Collection, UVI Falcon, Audio Damage, Melodyne Studio 4.2, VocAlign, Eventide (Everything), IL Vocodex, IL, Softube and IKM Total Studio Max. As of 18 Nov 19 |
I opened a new feature request post in Presonus Answers:
CS18AI & Studio One feature requests and manual Please vote for it to get more functions for CS18Ai to control Studio One. Thank you.
Windows 10, Intel I7-7700K, Gigabyte GA-Z170X-ULTRA GAMING, 16 GB RAM, Sonodyne SM 200AK, ESP 400Series Telecaster, Ibanez LR 750, Fender Precision Bass, Presonus Quantum, SSL Nucleus, IGS Global Summierer, JDK Audio R22, SPL Phonitor Mini, Drawmer MC2.1, Studio One 4 Pro, Jamstix 4, Lexicon, Melodyne, Mastering The Mix, Plugin Alliance, SSD5, EZ Drummer 2, Waves
darthMatthis wroteSorry if this has been covered elsewhere, but is it normal that I do not have control over 3rd party plugin parameters when selecting them? No. however the parameters need to be manually added for each plug via control link in studio one. |
Users browsing this forum: sjc193 and 1 guest
