Here's a little list I created.
CS18 WORKING FEATURES Faders, Mute, Solo, Select, Pan Faders control DAW faders Busses are in “Mix Masters” FX Busses are in “Returns” “Mute” mutes DAW channels “Solo” solos DAW channels Pan is controlled by 16 encoder knobs at the top and can also be controlled by encoder under the Touchscreen for currently selected track. Select button color matches Studio One channel color Scribble strip Shows: channel name Automation mode Pan Control Link parameter for Plugins Record arm Hold "Option" and press channel "Select" to toggle record arm on/off per channel. When in record arm the scribble strip will display a large "R" to indicate an armed channel Channel layer navigation Channels 1-16, 17-32, and so on. Press Shift and channel layer to go to channels 65-128. Press CTRL and channel layer to go to channels 129-192. (Not implemented) Groups button used for mixer "scenes". Select a scene to hide channels not in the scene. Option to add a scene/group, page to show selected group with exit and delete buttons. FX/Aux Returns button show FX channels Mix Masters button shows buses Group Masters button shows output channels Flex Fader Pressing “Edit” in “Assign” section will assign currently selected channel to the Flex Fader Mix navigation Press Main Mix button to have the main L/R mix on faders Press Mix button 1 - 8 once to bring the associated send mix to the faders. Mix number corresponds with Send slot numbering from top to bottom Press Mix button 9 - 16 once to bring the associated cue mix to the faders. Mix number 9 - 16 corresponds with Cue Mix slot from top to bottom Automation modes Uses Mute group buttons. All On = All Read 1 = Read 2 = Touch 3 = Latch 4 = Write 5 = All Read 6 = All Touch 7 = All Latch 8 = none Transport Uses Transport buttons as labeled Modifiers for additional funcitons “Option” engaged - Stop is “Fast Forward;” RTZ is “Rewind” “Ctrl” engaged - Stop is “Next Marker;” RTZ is “Prev Marker” Solo clear Clear and channels that are “Solo” enabled FX Inserts/Sends Tapping FX on Touchscreen opens list of Inserts or Sends for selected channel Inserts - shows top down list of plugins on channel Sends - shows top down list of sends on channel Tapping plugin in Inserts list will map plugin parameters to 16 encoders Parameter names show in 16 mini screens per channel Parameter value shows in Touchscreen and via meter bridge Tapping again dismisses plugin from computer screen and unlinks plugin parameters from encoders Tapping Sends will select it. Send level controlled by encoder below touchscreen Jog Function The knob under the touch screen can be used as a "Jog" when enabled from the Markers button and then hitting "JOG" at the top of the screen. Control Link Mode De-activating all buttons to the left of the "Selected Channel" meters, activates the Fat Channel for Control Link assigning of the knobs and buttons. Foot Switch Make sure the CS18 is in DAW mode Select "System" Now go to Footswitch Mode Press it and you will now see a drop down If you can not see the DAW options, select the last option and then select again. You will now see 2 DAW options "DAW Rec/Start" and "DAW Drop Markers" Select the one you need and then press home.
Johnny Geib's Home Studio Trainer
Main Site https://www.hst-homestudiotrainer.com/ YouTube Channel https://www.youtube.com/channel/UCyrsF9 ... unUaVjDAog |
Hi my dear,
thanks a lot for compiling this list, it might be very helpful for me and other users to get more familiar with the facilities, the CS18 has to provide. After a week i purchased the stuff i'm dazed and confused to the best of my knowledge using the machine with S one3...i will print the list and take it for reference until the lines are burned to my brain....so thanks again for nice work!
Sorry for poor language, i'm not a native speaker!
Proud of: RM32ai , S One 4, SL24.4.2, Presonus Faderport, MBP13" 8gb with 1TB ssdHd mid 2012 running Catalina & Airport Express, Samsung outboard screen 24“, Asus msn55 16gb for UC only, iPad Pro 3rd gen 256gb running ios 13.3.1., Ipads 2&3&4 for monitoring purposes |
Thank you!
This really helps.
George Ware
StudioOne v6.6.2 Pro 64bit Waves SoundGrid Studio 2 Waves DigiGrid IOS Waves DigiGrid IOX Waves SoundGrid Server One PreSonus CS18ai & BCR2000 Control Surface Intel 6 Core i7 3.2Ghz. Windows 10 Professional 64bit. v20H2 Arturia KeyLab-88 Essential URS, Waves v14 (Everything), EMI, Sonnox Oxford (Everything), Antares Unlimited, Plugin Alliance (Everything), Nomad Factory, TL Labs, Massey, Komplete Ultimate 13 CE, Arturia VC9 (Everything), Korg Collection, UVI Falcon v3.1, Melodyne Studio 5.2, VocAlign, Eventide (Everything), Softube and IKM Total Studio Max. As of 20 Jun 23 |
