Discuss the new Studio 192 and Studio 192 Mobile here
Whenever I turn my Studio 192 audio interface back on, the gain settings for the inputs are reset to zero. How can I make my Studio 192 remember my gain settings?
If it's of any help, I had to bypass the mixer in Universal Control to avoid bleed between the inputs and outputs.
by mycbeats on Sat Jul 16, 2022 11:59 pm
Settings will be remembered if you use the universal control mixer.
You should fix your input/output routings which is as simple as choosing each mix output and muteing the inputs.
Toronto, Canada
Project engineer by day, sound connoisseur by night.
Main Rig: Windows 11 (21H2) 64-bit, Ryzen 3900x, 32GB RAM, RTX 2060, dual 4K Monitors
Presonus 192, Faderport v2, Atom SQ, Akai Advance 49, Keystation 61 mk3, 2x Behringer X-Touch Mini + way too many synths.
Mobile Rig: MBP M1/16GB, Atom SQ, IOstation
by florentherbinger on Mon Jul 25, 2022 12:19 pm
It turns out that uninstalling and reinstalling the drivers fixed the problem; my Studio 192 now remembers the gain settings, even with Universal Control bypassed.
However, I'm still interested in fixing the bleed between the inputs and outputs. Could you please send a screenshot showing how to mute the inputs on each output in Universal Control?
by florentherbinger on Mon Jul 25, 2022 12:45 pm
I think this is what you mean. Can you confirm?
by mycbeats on Mon Jul 25, 2022 1:25 pm
Mute everything on each of the outputs, then unmute DAW 1-2 on Mix 1-2, so on.
Toronto, Canada
by florentherbinger on Tue Jul 26, 2022 7:42 pm
Perfect, thanks for the help.
