Whenever I turn my Studio 192 audio interface back on, the gain settings for the inputs are reset to zero. How can I make my Studio 192 remember my gain settings?
If it's of any help, I had to bypass the mixer in Universal Control to avoid bleed between the inputs and outputs. |
Settings will be remembered if you use the universal control mixer.
You should fix your input/output routings which is as simple as choosing each mix output and muteing the inputs.
Toronto, Canada
It turns out that uninstalling and reinstalling the drivers fixed the problem; my Studio 192 now remembers the gain settings, even with Universal Control bypassed.
However, I'm still interested in fixing the bleed between the inputs and outputs. Could you please send a screenshot showing how to mute the inputs on each output in Universal Control? |
Mute everything on each of the outputs, then unmute DAW 1-2 on Mix 1-2, so on.
Toronto, Canada
