Hello friends! Thanks in advance for any help you can provide. I recently purchased the 192 and loved it for the first week...until I was forced to update the firmware. At which point things went very very south. Now whenever I use logic or ableton the audio progressively becomes more and more distorted. Other words to describe it would be crackling/bit crushing.
I've read these forums and have seen other people have had the same issue. I haven't really found a solution though. I have reached out to support and opened a ticket. For weeks now we've been going back and forth. They're nice, but take way too long to reply - probably because of a heavy work load (that's not good, right?).
Anyways, I'm pretty discouraged at this point. I was REALLY hoping to resolve this issue, but now I'm starting to think it might be a common problem with either the 192 or UC. I wanted to be a fan of presonus, but so far this has been a terrible experience.
Running on a 2013 Macbook Pro High Sierra 10.13.2
UC 2.5.1
I'm using a USB 2.0 cable.
I've tested other audio interfaces and they're not giving me these issues.
by stefanrauch1 on Thu Dec 28, 2017 12:14 am
It is possible to revert your interface back to a previous firmware by uninstalling current UC and then install an older version of UC instead.
After installation and start of UC, you can replace firmware.
Downloads here:
https://www.presonus.com/products/UC-Surface/downloads
There is a link called: "Show / Hide all versions of software downloads"
I recommend you try UC version 2.1.1 first. If the firmware that comes with it does not work, you might have to go back even further... something like version 1.8.3
good luck
OS: Win10 x64 || Software: Studio One Pro [latest version]
Hardware: AMD Ryzen 9 3950X || Asus Prime X570-PRO || 64GB DDR4 RAM || Asus Dual-RTX2070S-A8G-EVO || UAD2 Octo & Duo PCIe
Peripherals: RME Fireface UFX II (+2x ADA8200) || Faderport Legacy || Atom || NI Komplete Kontrol A25
Audio Settings: 44,1/48kHz, 256 Samples, DP Off, 64 Bit
by garretmyers on Thu Dec 28, 2017 4:59 pm
Thanks for the reply, I’ll give that a go tonight!
by rokko101 on Tue Jan 16, 2018 9:56 pm
Hi there.
My experience about this issue has been almost the same.
I'm using 3 different Mac computers: Mac Pro 5.1, MacBook Air 2013, Mac mini 2012.
The problem began with Mac OS 10.3.2 update. Apple stated that they fixed some compatibility issues with third party USB audio devices with this release... well... while doing so they broke compatibility with some or most systems running Studio 192.
I've tested the latest UC version/firmware as well as the previous one with no success.
I've reported the bug directly to Apple ... but ... I don't know with they'll take the time to review this issue.
Presonus technical staff has been very kind and helpful as usual... but from what I understood they don't consider the problem their fault because it's apparently system dependent.
The problem with my Mac Pro has no solution... wether on USB2.0 or 3.0 I invariable get a nasty distortion about 15-20 seconds of playback. Things a better on USB2.0 but I can still hear sporadic pops.
On my Macbook Air things get a bit better... sporadic pops on USB3.0 but apparently fine on USB2.0.
Presonus recommends to use USB2.0 cables but I've used USB3.0 from El Capitán to High Sierra 10.3.1 with no problems whatsoever.
So... the solution right now is to stay or roll back to OS 10.13.1... At least here - that works.
MacOS 12.6, Mac Pro 2012 Xeon 3.06Ghz 24Gb RAM, Mac Mini 2012 i7, Studio One v.6 , Presonus Studio 192, AudioBox iOne.
by webhamster on Sat Jan 20, 2018 8:47 am
I have exactly the same issue. Even tried replacing the USB cables and switching to USB2 but so far no luck :(
S1 6.5.1 - MacOs 13.6.2 MacBook 14" M1 max - interface: Quantum 2
by webhamster on Thu Jan 25, 2018 4:08 am
Tried re-installing High Sierra, but that didn't fix it (I kept ending up with 10.13.2).
Eventually I 'upgraded' to Sierra (had to do a full re-install for that. S192 works great again. Apart from the crackling High Sierra never worked very well with a number of plugins and Presonus software.
by musicchamber on Sat Jan 27, 2018 5:46 am
Exactly the same issue with me. macOS 10.13.1 works so don't upgrade beyond that. I have had many exchanges of support emails, In the end I found that disabling the Presonus Hardware Support fixed the issue in macOS 10.13.2 and 10.13.3.
Obviously disabling the Hardware support, is not a good situation to be in because it renders the Studio One interplay with the 192 pretty useless in the Console and recording / mixing.
Very disapointed that Presonus cannot sort this out, my gut feeling is it's a clocking issue, because the time between the blips / pops vary depending out what pitches are being played i.e on a VST virtual instrument. ALSO the blips / pops get obviously more extreme when playing a chord!!
I'm sticking with macOS 10.13.1 until / if the problem gets sorted.
I have created a test disk / drive with the latest macOS builds and Studio One / UC firmware - a brand new spanking clean Install of macOS with no third party VST / AU only using Presonus instruments , this makes it easier to test without having to worry about 3rd party VST being the problem etc.
Studio One Professional v6, Apple iMac Pro 14 core, 128gb memory, 4TB SSD. macOS Ventura, Main audio interface is RME Babyface Pro. Presonus 192, DP88 (not currently used), RC500, ADL600, Focusrite ISA430, TC4000 reverb, SPL Phonitor, Monitoring: Event Opal, IK Multimedia MTM Studio Monitors x 5, DMAX audio Super Cubes. HD800s mastering reference headphones. Sequential Prophet 12, Prophet 12 modules x4, E-MU 4XT Ultra, Roland Fantom 8, Korg Pa3x, Roland Fp7-F, MOTU midi express 128, Xkey air 37, Studiolive CS18, Atari STE with Notator plus loads of microphones and plugins etc
by kdavies on Mon Jan 29, 2018 10:30 am
Same issue on Windows 10, USB 2.0 and 3.0 cables, Clean install. Old install
Taking a huge loss in the pocketbook and switching from a 192 to a Quantum resolved the problem immediately.
by musicchamber on Wed Jan 31, 2018 7:18 am
UC Control update 2.5.2.45951 and the applied firmware update to the 192 and also Studio One 3.5.5 have fixed all my issues now.
I can now use macOS 10.13.3 without any clicks/pops etc
Thank you Presonus :)
by marcz on Mon Feb 19, 2018 4:47 pm
Version 2.5.2 doesn’t fix this problem on Windows 10.
by christiannovak on Wed Apr 04, 2018 10:30 am
I have the same issue. My System: Windows 10.
No solution in sight?
by christiannovak on Thu Apr 05, 2018 3:43 am
Version 2.5 does fix the issue on Windows 10.
by jBranam on Sun May 20, 2018 7:03 pm
so this has been fixed on Win10? i am thinking about grabbing a mobile
“Life is so constructed, that the event does not, cannot, will not, match the expectation.”
Knot Hardly Productions
¯\_ { ͡• ͜ʖ ͡•} _/¯
by rokko101 on Thu May 31, 2018 6:00 pm
I can confirm the problem was fixed for Mac OS (High Sierra 10.13.3/10.13.4). I hope it's fixed for W10 as well.
