Discuss the new Studio 192 and Studio 192 Mobile here
How do I get the factory presets to load? I only have an "Audition" button and NO "Load" button. The manual suggests:
5. Load. Loads the current preset to the selected channel.
6. Audition. By engaging the Audition button, each preset will
nondestructively load into your channel with the currently enabled
filters. This lets you try out a preset before loading it and overwriting
the current settings. You can make changes to this preset in real time.
To load the settings you’ve auditioned, click the Load button.
My Universal Control v2.5.1.45526 has NO such button ... see image link below:
https://drive.google.com/open?id=1t3OO6 ... alkvTjrynR
My DSP is v1.8-31 firmware.
As a work around I leave the Audition button active but obviously this is not persistent and will go away when I power off.
Any suggestions?
Cheers, Rob.
by stefanrauch1 on Wed Dec 27, 2017 11:57 pm
The Load-Button is actually labeled "Recall". I think that might be what you are looking for.
best regards
Hardware: AMD Ryzen 9 3950X || Asus Prime X570-PRO || 64GB DDR4 RAM || Asus Dual-RTX2070S-A8G-EVO || UAD2 Octo & Duo PCIe
Peripherals: RME Fireface UFX II (+2x ADA8200) || Faderport Legacy || Atom || NI Komplete Kontrol A25
Audio Settings: 44,1/48kHz, 256 Samples, DP Off, 64 Bit
by robainscough on Fri Dec 29, 2017 6:04 pm
That was it!
Thank you.
Cheers, Rob
