I own a Studio 192 interface but I'm not happy with UC Software, i don't use the Fat Channel or the FX. Presonus needs to Put a Bypass Button in front of the Fat Channel. i Have to go to settings And put Bypass to the mixer, and also the UC Software needs more options like changing the buffer size in the mixer.
Presonus needs to Put a Bypass Button in front of the Fat Channel. There is a power button for each fat channel processor. Just turn them all off if you aren't using any. UC Software needs more options like changing the buffer size in the mixer. All those adjustment are in the UC Startup screen. If you aren't seeing this, look in the sytem tray for the UC icon and select. |
I know you can turn off the fat channel effects, The UC software is useless when you are using other DAWs. I think they need to fix the UC or Remove the UC Software from studio 192.
I'm afraid it is hard to understand tour issue. As Matt stated and you agreed there is a button to bypass the Fat Channel. Audio settings are adjustable in Universal Control screen. ????
The last clue is you mentioned use with other DAWS. Could you be more specific? Also, it helps the community assist if we know your system specs. To add your system specs to your signature follow the link in my signature to add. Skip
Skip
