Hello,
I have Studio 192 Mobile and I use Studio One 3, and when I create a new session in the system, it changes to Mixer bypassed and the Main of the interface is disabled, it goes out and I can only monitor by headphones. How do I solve that? Thank you. |
The mixer in UCS gets bypassed when you have an output designated as a cue mix. Check your output settings. Sounds like something is off there.
Are you using a template for new songs? If you correct the problem, you will need to re-save the template or it will keep happening. |
Has anyone had problems with the main output gain of Studio 192 Mobile. My main output is much lower than St 1/2 and St 3/4 outputs. St 1/2 and St 3/4 outputd have lots of headroom and the main out is padded by 40 db. Had to send the unit back. This is the second unit I received where the main output gain does not have any headroom----maybe poor quality control from Presonus??
Rodger |
