When I hook up my external stereo compressor, channel strip or even reverb unit I am getting a loud screeching sound.
I am coming out of the 192 channels 7/8 into the L/R of the unit and back into 7/8 of the 192. As soon as I turn the unit on I get a loud screeching sound. I tried looking in the manual and could not find a solution. What am I doing wrong? Thanks |
Why are you plugging the output of the 192 into the input pf the Compressor then back into the 192?
That is a direct feedback loop. Because there is no insert I/O path in the 192 suggest you use the channels strip before the 192 and send a line out to the input of the 192 since it can take a line in signal. (Assuming you want to process the input) However remember the 192 has a fat channels for the input and built in rev for output monitoring so most likely you don't need those other devices.
Thanks @jpettit for your quick response.
I have some outboard gear (SSL Master Bus Compressor, DBX 160, Chandler Limiter) that I want to use with Studio One. Pipeline makes it easy to integrate outboard gear with Studio One, so I thought. When I used my outboard gear with my other interface (Digi 003, RME) you came out of the gear, into the interface and back out to the gear. So I assumed it worked the same way with the 192. |
Oh ok gotcha.
You are using them in pipeline configuration. I do not personal do that but Lawrence does. You could PM him. I would guess you would have to go out one pair and in another pair and would also guess the pipeline prevents you from creating a feedback loop.
memberlist.php?mode=viewprofile&u=282
Lawrence You could turn down the input monitor in the UC. Not in studio to test. Recommend first opening S1 and see if pipeline plugin lets you pick the same number input as output.
