Hi.
Even if Sends A and B are set to -Inf I can still hear some delay and reverb applied to DAW Mix. The only way to completely bypass FX is to turn them off. This has to be some sort of bug. |
It would seem that way, but I have one question. If you are using the 192 template in Studio One, that template has fx set up as sends in the daw. Could that be what you are hearing?
Is the bleed coming through the mains, or some other output source? |
Hello Matt.
I've checked and there's no -inf. It's possible to go down only to -84 dB with the faders. That may explain why I can still hear also dry signal even if the fader is all the way down. I guess something similar is happening with sends. I'm using headphone outputs 1 and 2.with Main Mix as source. Also worth noticing that at Unity gain iTunes clips all the time. |
