Page 2 of 2
Re: usb 3 driver for Studio 192. PROBLEM!!!
Posted: Sun Jun 12, 2016 6:50 am
by prock
Just wondering why you are still using Cubase 32 bit? Try installing the 64 bit version. It works much better.
Regards
Posted: Fri Jun 17, 2016 11:43 am
by ramizgadzhialiev
I have 32 bit and 64 bit Cubase. Most often I use 64 bit. But you do not think that should work well everywhere? I have already put 8.5.20, but still the old problems remain. Who is guilty? To be or not to be))
Posted: Fri Oct 20, 2017 2:27 pm
by jesusrivera2
I have the same problem with the latest updates, i get 1-3 sec stops on audio and midi in cubase 9. i made a test with the same audio in Studio one and i didn't find any problems in studio one, i think Studio 192 only works in Studio one.
Posted: Tue Oct 24, 2017 6:50 pm
by jesusrivera2
jesusrivera2 wroteI have the same problem with the latest updates, i get 1-3 sec stops on audio and midi in cubase 9. i made a test with the same audio in Studio one and i didn't find any problems in studio one, i think Studio 192 only works in Studio one.
I find the problem it was a plugin that was doing the stops. i remove the plugin and it work without an problems. so if you find your audio stops for 1-3 sec make sure check your plugins effects.
Posted: Sat Sep 22, 2018 6:14 am
by jameshickey1
i7 3770 3.4 Ghz 24 GB Ram Win 10 Pro latest update
Cubase Pro 9.5 64 Bits
Studio 192 having erratically behavior on USB 3 port. Notice after latest firmware update
I know I'm not the only one with the problem.
Picture uploaded with the Cubase with The Average Audio Processing load indicator going crazy with annoy sound.
Help very much welcome.
James
