The new gear sounds exciting! I'm wondering if I can slave my 181& via light pipe?
I would like to know this as well.
It would be nice if I could make use of my 1818 as I paid a good price for it, and would be upset if I had to relegate it to defunct status. In theory it should work as a slave input over adapt, but I am no expert. Hopefully a Presonus tech will chime in.
Athena 4U Chassis i7-3770K Processor 5.0GHz(OC)|Gigabyte Z77X-UD3H|2 X 4GB Patriot Viper Extreme DDR3-1600|2GB Crucial SSD|SanDisk Extreme Pro 500GB SSD|SIIG 3 Port 9 wire Firewire Card|VIA 3 Port USB 2.0 Card|LG DVD/CD Drive|Gigabyte GTX 750 1GB(OC)|S1 Pro 4|D-Link DIR-615|Edirol UA-700|AB1818VSL |AS-900T IE Monitor System|Studiolive 24 S3|Studiolive RM16L|Alesis SR18|Digitech Vocalist Live Pro|Behringer DSP2024P|Nektar LX88+|Alesis Strike Force E-Drums|
On the surface, I would say that the 192 can not act as a preamp, based on the fact that both units provide internat fat channel processing, and that usually requires direct connection to the pc.
I am working on clarifying this to be sure. |
Kurt Weber wroteI'm guessing you mean the 1818 can operate in stand alone? I've been wondering the same thing. Can I use my current setup of 1818vsl and d8 as 16 extra inputs via adat with the 192? I would think so, but it would be nice to know for sure, before throwing down $. No. The 1818 must be connected to a pc/mac work. The Studio 192 can work standalone. |
Hey Matt
So does that mean we can slave the 192 to the 1818 then? Cheers
Yeah Jeff.....I believe that's exactly what Matt's saying. In theory, any interface with ADAT I/O that can operate in standalone can be slaved to the 1818. Before I got a D8 I did this with an old MOTU 2408.....no pre's but 8 more channels of I/O.
