I've been using my Studio 192 for several years with excellent results. I've added an Audient ASP880 for more inputs, and have connected it to the Studio 192 via fiber optic/lightpipe, and slaved its clock to the S-192. I've recorded many tunes successfully with this setup.
Recently I began using the both effects channels but I cannot figure out how to send the main 2-channel output with the effects to Capture 3. I've set up the S/PDIF channel (9-10) as the Output Source (see attached) and it is not receiving any signal. As a hack, I've routed the main outputs back into channels 7 & 8, and turned up the volume knob on the front of the console. ![]() There's gotta be a better way to record the main output with effects. Does anyone have the solution? |
