Console -template-
Posted: Fri Jun 22, 2018 9:45 pm
Hello.
If you have the GPO 5 (Garritan Personal Orchestra 5) library here's an upload of a empty song template and simple demo's I've made.
The Notion document file is called -Console- .
I'm hoping folks will download and try it. Cool if they put some work they've made with it here for us to listen to.
Composing music should be the majority of the time spent using Notion. Hopefully this template will make it simple and fun to compose organ parts in Notion after getting used to how it works.
-Console- uses the GPO 5 Custom Organ Console preset.
The music demo example I've added isn't that impressive or complex. Wanted to keep it simple and short.
Been wanting to experiment on different ways to get more automation within my Notion scores, forever.
Spent a lot of time trying to learn how I can get better at using Notion. The generally target being audio recordings. Time spent finding way's to avoid hangups. And to find and create the workflow I think is best for me. Also to define and except what I can't get Notion to do too.
I have not really spent much time testing how the "Console" will work in practical daily use on complete score composition. But so far it seems to me it could work for music from Bach to Beethoven. Rock and future. Tried to layout the basic Score Setup as best I could think of for now.
It visually is not intended to be for convention notation and print. But is intended for composing with playback and less distraction from eye motion. i.e. leaving the score window to check realtime controls in another GUI viewing window?
[BTW, I've heard some vsti developers recommend viewing it's GUI while preforming. At least while editing and auditioning it's sound and response.]
Here is a list of things to help use the template -Console_ notion file.
Take care and avoid unconsciously deleting the attached staff rules and other staff assignment changes.
Of the x01-20 Notion Express Entry technique shortcut key's used...
• x01-12 = turns sliders 1-6 on/off.
(Odd numbers = off.
(Even numbers = on.
• x13-17 = MIDI cc10 panning L to R (x15 = C).
x20 = Reset instrument to the Console preset default settings.
• Put rests on single-line staff's where desired. Attach dynamics to those rests and connect using hairpins to modulate up and down the
registered slider value during playback.
• Use the Sequencer staff to improvise difficult transcriptions and record other MIDI control change.
-Skipped YouTube. Here's a MP4 demo screenshot video to download if desired.
Hope Notion will soon find ways to implement some similar type of automation. Using other yet similar and smaller display elements.
Anyway, if you have GPO 5 try this out. Hope you have fun. Give some example
,Newberry
(Odd numbers = off.
(Even numbers = on.
,Newberry
