Ceres 4.5 subwoofer crossover frequency
Posted: Thu Oct 20, 2016 4:49 pm
Hi everyone!
I wasn't able to find the frequency at which the sub output is set (Ceres 4.5BT) anywhere in the documentation. Does anybody know this (80 Hz, 100 Hz)?
If it's too high (ie 100 Hz) I will probably connect mine to a small sub I'm planning to buy (Fostex Submini) through the sub's crossover and set the freq. a bit lower (70-ish Hz) since it's not a very powerful sub and will probably be better to feed it only frequencies which Presonus are not able to produce well..
Cheers!
Cheers!
