I have seen others ask this question with no definitive answer from Presonus... The RM32 user manual does not include the pinout. The AI series 32 channel manual shows the pinout from the AI 32, but that does not tell us what the pinout is on the RM 32.. The AI32 uses the Tascam db25 std pinout. what does the RM 32 use?
All db25 on the presonus mixer series have the same pinout.
I am using the Hosa 800 series (DB25 to XLR) snake and it is wired correctly. I've attached the spec sheet for this product that diagrams the pinouts.
Hey gang! Been using Studio192 but it has the DB25 Pin in/out. I am going to try to get that working so I can add more inputs. I see the Hosa product which I will order. I hope to be able to run the drum room harness to the to the DB25 input. But what Do I do with the outputs? Thanks!
Jerialice
