Hi there!
I have tried to research and didn't find anything that worked. I bought a MacMini (mid 2011) and I am trying to connect my StudioLive RM32AI, when I connect it nothing shows up. I have checked the cable with my laptop and it works without a problem. I have got 2 screens connected through HDMI and thunderbolt (only have one HDMI port), but I also tried disconnecting everything and just connecting the mixer to Firewire 800 and also to Thunderbolt, but still no luck. The Mac does recognize it somehow because under System Report/Firewire I can see the mixer. I will attach some pictures. Here you can see that the mixer is being detected https://ibb.co/tsMd7Pg It is not showing up under audio devices. https://ibb.co/rknJD3P https://ibb.co/vmSpGkz I hope you guys can help me, thank you! |
wahlerstudios wroteMaybe this can help: That worked perfectly! Just did it and I am able to record without problems. I installed UC Surface 1.7.6, restarted it and I could already see it under audio devices. Then downloaded the latest version and didn't install any drivers, just UC Surface and it's working!! I appreciate your help a lot, thank you! ![]() ![]() |
