As most folks know, with the RM series, while there are more modern firmware versions, 9244 is the most stable. Was curious what folks would think was the better recommended version of UC Surface to use accordingly, for no latency on meters and changes seen when moving sliders.. be it wired direct to the PC or using the wireless dongle in the RM unit to the Router.
It was listed in the Release notes as:
Known ​​Issues:​​​​​​
UC​​ Surface:
Control​​ and ​​metering ​​on ​​UC ​​Surface ​​instance​ ​connected ​​via ​​Firewire ​​may ​​exhibit ​​lag ​​on some systems
and
Copy, Delete, & Rename Local Scenes for Cascaded AI mixers not functioning as expected
According to Release notes, v3.2.0.56558 fixed the Control​​ and ​​metering ​​on ​​UC ​​Surface ​​instance​ ​connected ​​via ​​Firewire ​​may ​​exhibit ​​lag ​​on some systems. Can anyone say that they see that solved then as well?
Then with v3.2.1.57677 the Copy, Delete, Rename still exists, but a few new issues added.
v3.3.0.59348 added additional issues.
Anyone using a stable version they can highly recommend? Or 1.8 / 2.0 still the most stable?
Im going thru all the UC Surface release notes, seeing whats newly added, what was fixed, vs still known issues, looking for the "lesser of the evils" for most stable
PreSonus Studio One 5.1.2 Professional-64 Bit
Lenovo ThinkServer TS140, Win 10 64Bit, 28GB RAM, (3) SansDisk 480 SSD
Quad Core-3.20 Gigahertz Intel Xeon E3-1225, (1) SandDisk 240 SSD
Texas Instruments 1394 OHCI Compliant Host Controller, Firewire & Ethernet connection
RM32AI, RM16AI, FaderPort, Melodyne Celemony, JBridge, Way too many VSTs to list
MOTU AVB, iPad 4 x2, Netgear NightHawk AC1900 Router, Avid ElevenRack, ADAT Edit
Coleman LS3 Line Switcher, Goldpoint SA1X Stepped Volume Attenuator, pre Monitor switch
ATC SCM25A PROs 3-Way, Alesis Monitor Ones 2-Way, Avantone MixCubes 1-Way
by michaelwalter on Wed Sep 30, 2020 8:35 pm
Looks like this ticket sums it all up
viewtopic.php?f=222&t=25503
1.8 and happy...
