I use a lot of Waves plugins in post prod with Pro Tools on recordings made using Capture (from live broadcast sessions). I'd quite like to use those familiar plugins live as well as inserts/sends on the RM32. Read an article on Waves website that talked about running Multirack on a Mac or PC via the Firewire port on the RM.
BUT, I currently use the firewire to record to Capture. Assume I'm a bit stuffed with this unless anyone out there knows of a better way. Anyone else using Multirack successfully in a live setup? |
waves multirack can work together with capture over firewire without problems. i asked the waves support exact the same question a few weeks ago. a trial of multirack confirmed this working very smooth. right now multirack is too expensive for me, i'll wait until an offer comes on the waves side...
until this i use studio one to run plugins and record at the same time...also works good.
SL1602
RM16AI Nowsonic stage router StudioOne pro2 mac book pro 2009 ipad4 db technologies DVX 10(2x), DVX8(4x) db technologies S08(2x) https://www.waves.com/r/bqvxon |
Wait... - it's not that easy. Besides a direct FireWire connection (mixer <-> computer) there is AVB or Dante as network alternatives and it has to decided, what the input per channel is: Mic/Line (preamp) or FireWire/Network. The RM mixers offer no digital insert or routing and AVB can only make dedicated devices talk to each other, so Dante seems to be the only route to follow.
The question is how to add external processing in a live situation with two RM32AI involved and a CS18AI controller. To a certain extent the 64 channels in a Master/Slave configuration do offer some flexibility. At least you can route the 32 channels of the Slave internally as network inputs to the Master and record 32 channels through FireWire. On the other hand you can record 64 channels through FireWire, when AVB is involved and Studio One is part of the AVB network. How that works together with the Studio One integration to the CS18AI and the mysterious DAW button, is not really clear to me. My Mac mini is not the best computer to test this kind of configuration, which I anyway don't need, but I would be interested to get a better understanding of how things work together and what kind of solutions are possible. AVB plays a mysterious role in this whole "arrangement", so it is worth further investigations... AVB II will have the integration of external devices, like it was shown on the NAMM show. The SL32 was connected to a prototype of a new Waves SoundGrid Bridge. Have a look at this video (https://www.youtube.com/watch?v=jf0ZZvT5WgU) from 4:39 to 5:18. AVB II, not AVB I... |
Ignore the above -^
AVB in RM will not talk to a computer. Dante can't be used if you're cascading the RMs. FireWire will work perfectly fine. Especially easy on a Mac. Cascade the RMs with AVB and connect CS18 as normal. Connect FireWire from Master RM to Mac and use Capture to record as normal. Run Waves Multirack Native and patch any required channels. Select FireWire on each RM channel that you need inserts from Multirack. Its that simple.
Karyn
Interestingly enough waves are no longer listed as an avnu alliance member and I can't find any other mention of the avb bridge.
Funny is also that waves have a document as to why avb is not a good option for their architecture. Their faq comment about avb commitment seem to be gone as well. http://www.waves.com/1lib/pdf/soundgrid ... ompare.pdf Audinate did a similar thing when they decided to cancel on avb and invested in aes67 instead. I'm hoping that waves will look into aes67 and aes70 in the future as that would be a killer for my setup. Today I have to rely on using the x-wsg option card in my x32 to gain soundgrid support. What is the roundtrip latency with sl-mk3 using avb into a decent mac and studioone used as a channel insert on the mixer? wahlerstudios wroteThe RM mixers offer no digital insert or routing and AVB
It's not as complex as it sounds Phil, just requires a little logical thought following the signal path through a channel.
Mic in > preamp > FW Out > Computer > Waves Multirack > FW Return > FAT Channel... Just ensure the FireWire is selected as INPUT on every channel you need Waves..
Karyn
Phil,
I use Waves MultiRack and four separate Waves Plugins in a live situation with my two RM16AI's cascaded with my CS18. I also run Capture at the same time on the same computer and I've had no issues with the setup. I use a refurbished HP Business laptop computer thru FW (see specs below) and the CPU usage and Memory never exceed 32%. I've done about 40 shows this year with this setup and it's never let me down. I can tell you that the Waves Plugins that we use do wonders for vocals and it's about as simple to implement as can be. I paid $340.00 dollars (US) at Staples.com for the computer. HP 6470B Business Laptop 14in Display with LED backlit HD anti-glare screen & Intel Graphics Intel Core i5-3320M 2.6Ghz Processor 16GB Memory, 750GB Hard Drive, DVDRW Windows 10 Professional 64bit Cheers!!!
2 Presonus RM16AI, CS18AI, AudioBox USB, AudioBox 1818VSL, Lenovo 560 23" All-In-One i5/3.0ghz, Dell Pro Venue 10, HP Pro612 Tablet Presonus StudioOne Professional, ERIS 8 monitors, Alesis Elevate 6 monitors, AKG K141 headphones. Budda SD18, SD30, and SD45 amplifiers, Marshall JVM 205H amps and cabinets. Gibson Les Pau Standards, Classic, Traditionals and Signature. Carvin XD360 Speaker Management System. Mackie subs and Mains. Crown Power Amps and AKG Tetrad Quad Wireless Mics.
Four plugins in total or per channel? What is your latency running it in your setup?
Which plugins do you use? My macbook pro from mid-2009 can only run five instances of the j37 in stereo before it barfs but with the impact server i can run 22 instances. robertbernard wroteI use Waves MultiRack and four separate Waves Plugins in a live situation with my two RM16AI's cascaded with my CS18.
So for our typical live set up we run all of our tracks through MultiRacks, normally 16 channels....
4 vocals 2 guitars 1 bass guitar 1 kick drum 2 floor toms 3 rack toms 1 snare 2 overheads We run the following Waves Plugins on each Vocal Channel.... Renaissance DeEsser Renaissance VOX Renaissance Doubler Waves Tune Real Time I also run the One-Knob Fatter on the kick drum and the bass guitar. We have never had any latency issues that are noticeable and it works like a charm. I will say that my laptop is optimized for just this purpose so a lot of the garbage that slows down computers and uses disk space or resources has been eliminated.
robertbernard wroteSo for our typical live set up we run all of our tracks through MultiRacks, normally 16 channels.... most of us have heard that compression should not be applyed too heavy (or even not at all) on the moitor signal. Do you run this chain to the monitors as well or do you have the post send button engaged which sends the signal after the fat channel to your digital sends??
SL1602
The only video I have seen yet about RM32AI and Waves MultiRack:
https://www.youtube.com/watch?v=MCJmtPlrEQA |
We do not run any effects or compression thru the monitors. We run powered monitors that have built in EQ, delays, reverbs and such if we need to sweeten the monitors for the vocals. Haven't had any issues and I have to say that I haven't even thought about using UC Surface for the last 20 shows or so, the CS18ai is way more user-friendly and quicker when you have to make adjustments during the show.
robertbernard wrotePhil, Thanks for this - sounds more promising than I thought. I typically use WAVES SSL channel strips, HVERB, BSS DPR 402 compressor, Bass Rider, Vocal Rider, CLA pack and loads of others. If I can run this on the same laptop as Capture (MBP i7) then that saves on more hardware. I'll ponder. Thanks |
The computer stays on stage. With the plugins we use live, there is very little to change once we do a sound check, and since I'm also the guitar player in the band it's a simple as turning around to make an adjustment.
I own an RM32ai as well. I too wanted to integrate Waves plugins with this mixer. Outside of the native (FW800) interface, which adds too much latency even without plugins running - it can't be done. At least not for a live show. I recently purchased a Series III 32R, an SW5E, the Waves BR-1 and a Mobile server running Multirack v10. I am happy to report that this system works beautifully!
The BR-1 was pulled for revision, but Waves told me there was nothing wrong with them and it would do what I wanted. I run at least 2 plugins per group (vocals, drum, instrument) and 5 on my main LR. I also run X-FDBK on monitors, and PSE on vocal channels. Average of 20 plugins at once... No latency, no drop-outs. Usually at less than 40% cpu usage. All of this on the Waves mobile server!! After the "let down" of discontinuing the RM32, I didn't want to buy more Presonus gear. I got a chance to actually hear one and the preamps are even better than the RM. The effects are still lame, but I've routed Waves R-verb into my FX A and FX B and it's awesome. Stop trying to get milk from a horse and get an 32R... no regrets here! |
