70 postsPage 4 of 4
1, 2, 3, 4
Hey WahlerStudios, Are you still seeing a lag over Firewire with the beta Firmware and newest UC 2x? My biggest issue with it is the ghosting faders and pots, the meters are not as much of a concern. . . I have one more gig tonight then I'm free till May 17th so I'm going to try to test it ASAP after today.
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
by wahlerstudios on Mon Apr 30, 2018 1:18 pm
Yes and no... ;-) There is obviously a problem with older Capture recordings. I write more about it in the beta forum. Otherwise and especially if you are not depending on the meters (what you see is not what you get), everything looks quite fine, I would say.
Hardy
Apple routers | iPads | Alesis iO Docks | Yamaha S112, S15e, S10e, SM12, SM10 | LD Systems Curv 500 | Galaxy Audio Hot Spots | Mac mini | Lenovo Laptop | Studio One Artist 5.1.2 & Pro 3.5.6
by Karyn on Mon Apr 30, 2018 3:54 pm
"Locked" just means you can't post to it, you can still read it.
Karyn
Sonar Platinum, Studio One.
http://refer.waves.com/dzDVn
Dante Level2 certified.
by roblof on Mon Apr 30, 2018 10:03 pm
Nope, I’m getting a “you are not authorized” message if I try to read that forum.
Even if I might use these mixers on occation I don’t own one and therefor have none registered on me and is therefor prohibited to read that part of the forum.
Karyn wrote"Locked" just means you can't post to it, you can still read it.
Behringer Wing, iMac late 2015, Behringer X-Touch, X-Touch ONE, M-Air mr18, X-Air xr18, x32 with Dante/aes67, x32-rack with Dante/aes67, s16 and sd16 stageboxes, p16 monitor system, TurboSound iQ-speakers, Waves x-wsg with SoundGrid server, Motör 61, BCR-2000, StudioLive 24, FirePod 10, Apogee Ensemble, Alesis HD24, Studio One Pro v5, Notion 6, NI Komplete 11 Ultimate, Halion 6, Nuendo 10, Ableton Live 8 Suite, Reaper 4, misc Line6 gear/software, True Temperament Frets on basses and guitars, Korg Kronos, Roland vk-7, Behringer Deepmind 12, Behringer Neutron, Yamaha 02r.....
by Karyn on Tue May 01, 2018 3:19 pm
Ah, sorry. I assumed that as you're in the RM forum that you had an RM...
Yes, you're right. The beta sections are "private".
Karyn
by samfisher1 on Thu May 03, 2018 4:22 am
Logged in. RM Mixer registered on my profile. Still get message to say 'Forum Locked' or 'You're not authorised'. Any ideas please?
Sam
Desperately amateur, hopelessly passionate.
MacBook Pro - Mid 2017 - OS 10.13.6
3.1GHz Intel Core i7
16GB 2133 MHz RAM
StudioLive RML16AI
UC 2.8.0.48221 (Jul 5 2018)
UC Surface 2.9.0.49213 (Sep 10 2018)
Firmware v13731
Focusrite Scarlett 18i20
Apple MainStage 3.0
IO configured as Aggregate Device
by samfisher1 on Thu May 03, 2018 5:25 am
I'm definitely logged in and following the link takes me to 'you are not authorised to view this page'.
Sam
16GB 2133 MHz RAM
StudioLive RML16AI
Firmware v13731
Apple MainStage 3.0
by robranogajec on Fri May 18, 2018 8:42 pm
The problem I have is that until the FireWire lag is fixed, I can’t really update uc surface on my Mac mini. So having any new features delivered for my RM (remote RTA) still doesn’t help me. I am a bit disappointed that it has taken this long and it still isn’t fixed.
by wahlerstudios on Sat May 19, 2018 7:17 am
The term should be changed from FireWire lag to FireWire display lag, because that's what it was and still is, even with the beta firmware. FireWire (audio) works fine, but do not look at any metering display in UC Surface... It is now clear that the problem has come with UC Surface 2.0. The metering of Studio One, connected via FireWire, shows everything "in time".
I don't think you will miss so much by staying with UC 1.8 on your computer, because the firmware on the mixer is more important. It may well be that "good ol' 1.8" shows and does everything, when the firmware of your mixer is updated. "Sync Select" probably works, because it was already a feature of UC 1.8.
There is no "remote RTA". It's just the "go remote" function, which is the noisy part of Smaart. This feature is now available on UC Surface tablet, which of course needs Smaart on a computer. I have no idea if a combination UC 1.8 (computer) and 2.7 (tablet) can handle "go remote". Generally, there is no problem using both versions. You can use the new features, but the display on your computer is still "readable".
Why not check the beta firmware for your mixer and UC 2.7 on your iPad (if your iPad is young enough)?
by djangob on Sat Jul 18, 2020 4:04 pm
and stating that the display lag issue for meters continues on UC 3.X
StudioLive 32R; StudioLive 16R; Faderport 8; SW5E; Earmix16m; AR12; MacBook Pro 16” retina; MacMini (2020) MacMini (late 2014); OS X 10.15 ; AudioBox iTwo. Studio One 5 Professional ; Capture 3
70 postsPage 4 of 4
1, 2, 3, 4
