short version (i don't want to use the digital return in favour of two separate inserts for click vs backing attenuation for IEM's)
macbook pro Presonus RM32 is the selected Output Device Routed firewire returns to channels 16 and 17 16 click 17 mono backing track - using IEMS Youtube sound works as expected into channels 16 and 17 on my RM32 BUT iTunes? ZIP! What have I done wrong or what step have I missed? I suspect an iTunes preference setting to blame but I have been all over the net and can't find a solution that fits the bill. Anyone have some pointers to share? tia, Matty |
I have a ticket Open with Apple Care/ Support, will report back tomorrow.
This stuff frustrates me to no end! haha Wish me luck for a resolution to post back with. m |
I have experienced that iTunes will not update and recognize changes to audio properties while the app is running. Quitting iTunes and restarting will fix this issue. So if you are connecting to the RM after iTunes running this issue will occur.
bubbaguth wroteI have experienced that iTunes will not update and recognize changes to audio properties while the app is running. Quitting iTunes and restarting will fix this issue. So if you are connecting to the RM after iTunes running this issue will occur. Thanks bubba. I have done that a few times. Even rebooted the macbook. I did all the setting up while connected to the mixer. Wonder if that would cause that issue you mentioned? |
...after multiple failed attempts to reset I was finally bumped up to a senior advisor. Still no joy after booting in safe mode as well as after resetting some internal apple stuff that was going over my head. A head scratcher as it were. So, it was finally recommended that I upgrade to El Capitan and most recent firmware updated for my RM32. Reluctantly, I have done these. With a gig on the weekend and I am expecting trouble now. LOL
I am currently backing up my macbook to an external drive and I have already backed up UC as well as my scenes. I'll install all the required updates and retry. If it still doesn't work I am to call back to apple support and have an engineer look at the issues. Will report back here when I find out. |
Whew! I thought I was in the same spot you were for a minute. I went from 10.11.3 to 10.11.4 and tonight is the first time connecting to RM and I too could not get any audio from my Mac to RM. Everything came out of the computer speakers.
Possible solution for you? Check your audio configuration under Audio Midi Setup. For some reason the PreSonus FireStudio was no longer my default interface. If you highlight it, go down to the little gear and select "use this as my default sound output". I have been running this Mac since last fall on RM and Classic prior to that and I don't recall ever having to mess with this. I would say the Mac OS update did something. |
THANK YOU EVERYONE! I HAVE SUCCESS!!!!!!!
...can you tell how stoked I am? Long and short, installed latest UC Firmware and upgraded to El Capitan. Set my default listening device as the StudioLive RM32 In and Out Utilities - Audio Midi set up to ensure audio over firewire is still being sent to channel strips 17 &18 Click 17, or Left and backing trax 18, or Right. Now it all works exactly as I had hoped. Was really reluctant to perform these updates so close to a gig but it appears to have worked out nicely. saved the scene again as well as a back up for UC. Good to go I believe!! |
Nice. Updating FW can be a bit intimidating, especially close to a gig. We were far enough away from the update release, to where you would have been able to see problems beforehand. Now if you were updating the FW right when the update released, then different story. Unless the update was specifically fixing a problem you had, or had a "I can't live without this" feature, then it may not be a good idea.
But also keep in mind, you can go back to a previous FW version and UCS if needed. The FW reversal would require a FW recovery, which will wipe all settings, so a backup would be mandatory to preserve saved scenes and presets. |
Due to major performance issues with my mid 2012 running El Capitan, I had to restore my mac to Yosemite and reistalled a back up I created before the OS update.
So here we go again. Audio midi checks out. Test tones generate signal in UC on channels 17/18. Itunes playing but no sound and zero signal to UC. Stumped again. |
System Preferences message when Presonus is selected
Selected Device Has No Output Controls ???? I ensured that I have set audioi to stereo AND have successfully sent test tones via firewire to both channel 17 L (click) and 18 R (BackingTracks) to the RM32. I can see the audio on the front of the RM and in my UC. Still have zero audio going to RM from iTunes, youtube audio still works tho. I am beyond stumped. can anyone think of ANYTHING I have simply overlooked? |
There's a couple of articles in the knowledge base regarding audio settings on Mac. This article is a good starting point. Links to other articles are provided at the bottom.
As for audio apps you can divide them into two groups: 1 - Apps that have a menu/tab for audio interface settings/preferences 2 - Apps that simply use the interface defaults as set in OSX When, after you done all that is suggested in the articles, some apps refuse to take the defaults then those apps may be from group 1 |
http://support.presonus.com/attachments ... ic+Tab.png
This was this fix. Unbelievable, truly. I am very grateful switchback, thank you very much! |
OLD thread revived!
So all is working well except now, Youtube won't play through the RM. Backing tracks, itunes all good. When we try a youtube video it defaults to the Macbook speaker. HAHA I'm ??? again |
Users browsing this forum: No registered users and 30 guests
