I have an rm16 mixer. In channel 16 I have a xlr cable stuck. What do I do?
Per Johansen
RM16
by colinparry on Sat Sep 05, 2015 4:46 pm
I was able to free a stuck XLR plug in my RM16AI by holding the release tab in on the XLR socket on the mixer, pushing the stuck XLR plug in a little bit before then pulling it out. The plug only moved in a mm or two and I did not push very hard for fear of breaking anything, but it was enough to free it sufficiently. It only happened with me on a cable fited with a budget XLR plug.
MacBook Pro 15". OS X Yosemite
StudioLive RM16AI
iPad Air + Universal Control AI
Studio One 2 Artist & Capture 2
by perjohansen1 on Sun Sep 06, 2015 9:59 am
Thanks, I will try that. :)
Per Johansen
RM16
by perjohansen1 on Wed Sep 16, 2015 2:41 am
Cable still stuck in mixer.
Per Johansen
RM16
by drums.michael on Wed Sep 16, 2015 2:49 am
Unfortunately PreSonus decided not to use Neutrik Sockets so I'm not surprised this would happen eventually...
Which connector brand is on your cable?
RM32AI
- MacBook Pro Retina i7 8gb
- 2U self built computer running MacOSX Mavericks (courtesy of tonymacx86.com) and Hannspree/Hanns-G Touchscreen (HT231HPG)
internals:
CPU: i7 4790K @4.0Ghz
RAM: 16GB 1866 DDR3
OS disk 128gb Samsung 840 SSD
storage: 2 2TB Seagate HDD 7200 rpm (2tb running RAID for speed plus 2x 1tb storage partitions)
Chenbro RM24100 Rackcase
CPU Cooler (due to height restrictions) Thermalright AXP-200 Muscle with offset Fan
UC Surface on Mac and iPad
Processing via Waves MultiRack & LiveProfessor2
My Homepage (still being built...)
by perjohansen1 on Thu Sep 17, 2015 4:09 pm
Per Johansen
RM16
by joshuaratcliff1 on Sat Feb 03, 2018 10:58 pm
Was a solution found?
by Dale Christenson on Thu Mar 22, 2018 6:22 pm
I am curious if the lock could be removed without disassembling the mixer.
Sound 4-U! reinforcement and mobile recording serving Tulsa and surrounding areas.
Dale Christenson
918.261.7263
StudioLive RM32ai
StudioLive RML32ai
CS18ai
MOTU AVB switch
ULT15 x6
ULT18 x2
SL AI328 speakers x4
StudioLive 16.4.2 classic
Windows 8.1 SSD computer with UC Surface, Capture2, and StudioOne2 Producer
by roblof on Fri Mar 23, 2018 2:38 am
Nope,
Here is a video I did on the subject on my x32 a couple of years ago:
Dale Christenson wroteI am curious if the lock could be removed without disassembling the mixer.
Studio One Pro v5, Notion 6, Nuendo 11, BitWig v3, Reaper v4, Ableton Live 8 Suite, iMac late 2015, Behringer Wing/x32-BigBoy/x32-rack all with Dante/aes67 and s16/sd16 stageboxes, Flow8, Waves x-wsg with SoundGrid server, Behringer X-Touch, X-Touch ONE, M-Air mr18, X-Air xr18, DP48, Hub4 and p16 monitor systems, TurboSound iQ-speakers, Motör 61, BCR-2000, FirePod 10, Apogee Ensemble, Alesis HD24, NI Komplete 12 Ultimate Collectors, Halion 6, True Temperament Frets on basses and guitars, Katana-100, DT-50, JSX, JCM800, Korg Kronos, Roland vk-7, Behringer Deepmind 12, Behringer Neutron
by krashkarma on Wed May 08, 2024 2:03 am
This happened to me on a 32R mixer. i was able to get the cable back out. With a pair of pliers twist the XLR plug a few millimeters to the left and then you can pull the cable out.
