Page 1 of 2
Delete audio files from iPad after using Capture Duo
Posted: Thu Jan 29, 2015 10:09 pm
by Bbd
I recorded my church group tonight using my iPad with Capture Duo. I got home, launched S1 and then had Capture upload to my S1 song. That was great and very easy!
When I now delete the audio track from Capture Duo, does that remove the audio track on my iPad or do I have to use another method. I don't want those large audio files taking up room on my iPad now that they have been transferred.
TIA
Bbd
Re: Delete audio files from iPad after using Capture Duo
Posted: Thu Jan 29, 2015 10:19 pm
by mwright137
You have to use iTunes to delete them.
Posted: Thu Jan 29, 2015 10:26 pm
by Bbd
Thx much for the quick reply!
Posted: Thu Jan 29, 2015 10:35 pm
by mwright137
No prob. Had some assistance to verify...
Posted: Thu Feb 12, 2015 7:56 am
by nsmdigitalpc
How to permanently delete capture audio files from the ipad using iTunes
1.Locate the file in the Document list of the relevant application in the File Sharing section under the Apps tab of iTunes.
2.Highlight it.
3.Press Delete key on KEYBOARD of your computer.
4.Confirm Delete option in pop-up window that will appear.
Your good to go after this!
Posted: Thu Jun 02, 2016 8:08 am
by Scardanelli
Sorry to be dense but....just started using Capture and I cannot find the files using your method.
Could you please make it super clear for my slow brain - are you opening iTunes on the iPad, or in settings on the iPad, or are you synching with your mac/pc and opening there?
Thanks i advance !
Simon
Posted: Thu Jun 02, 2016 9:20 am
by matthewgorman
Simon, I think this needs to be done from the PC with the ipad connected.
Posted: Thu Jun 02, 2016 9:31 am
by Scardanelli
Thanks Matt - yep, got there eventually!
Posted: Mon Dec 05, 2016 7:08 pm
by focinalbert
worth sharing! helped me a lot.Cheers
InfantigoPiercingFordyce
Posted: Thu Jan 12, 2017 2:56 am
by menespark
Where to check the audio file in iTunes?
Posted: Mon Feb 06, 2017 9:32 pm
by menespark
Did a test with the app and it works fine.
Posted: Fri May 19, 2017 1:44 am
by jaketse
Hi there! If you want to delete data from your iOS device, you can try some powerful data erasing tools. I would recommend you iOS Data Eraser which can 100% wipe data from your app. You can refer tohow to delete iPhone data. But before you delete data, I suggest you backup iPhone to PC and save the audio files on your computer in case you will need them later.
Posted: Tue Jun 13, 2017 4:33 am
by gapefmrs
How to delete audio(song) from iPad read :reading: this thread :readit: complete guide with screenshot
Posted: Thu Oct 25, 2018 5:28 am
by jerrysmith20
To be honest, I just know how to delete captured audio files on MacBook. Recently, I record a lot of streams including Apple Music, Tidal, Spotify tracks with Audio Capture for Mac. Then I transfer them to my iPad with iTunes and delete them on my laptop.
Posted: Fri Nov 02, 2018 12:29 am
by rannyjohns
Frankly, I do not know to delete the files on my Mac and this solution more frequently help me more in this process, I got another solution through Error code 0xc00000e9 that wok me too, thanks for this.
Posted: Thu Feb 21, 2019 8:12 am
by williambosniac
Thx for the info i was having the same issue.
Posted: Tue Apr 02, 2019 3:33 am
by jenniesteinman
Heya did u find any solution to it?Facing similar issue...If yes then pls post here
dqfansurvey
Posted: Thu Apr 04, 2019 1:15 am
by ypkdidypkdid
I have ever use a audio + video recorder to capture video on Youtube, record Apple Music and Spotify on computer, it named UkeySoft Screen Recorder, which can capture screen, record video and take snapshot.
Read the guide how to record Pandora music to MP3
Posted: Thu Apr 25, 2019 3:12 am
by roymatas
Actually..Quality posts like this are worth sharing rather than sharing some useless stuffs..Very much informative
Posted: Fri Apr 26, 2019 3:48 am
by roymatas
roymatas wroteActually..Quality posts like this are worth sharing rather than sharing some useless stuffs..Very much informative
PS i fogot to add,pls odnt stop here..Keep sharing if u have got some more quality stuff..Thank you MyCCPay Login
