complex mix, channel vu failure
Posted: Wed Jul 11, 2018 1:28 pm
by bobcrownfield
I started a project which requires fat channel features
on all of the channels in use.
Capture shows me
input level after trim.
compression level
expansion level
but not channel volume. easy in16.4.2
(fatal flaw 1)
I can not assign channels 5-9 to a submaster,
then assign the submaster to the main. easy in 16.4.2
nearly fatal flaw.
rm16ai and surface
may be the only digital mixer ever made
that does not show post fader level.
does presonus let real people try the gear
before they freeze the design?
am I crazy, or
is there a way to show post fader level?
or am I the only person who thinks it is important.
check Master Fader from Mackie.
Re: complex mix, channel vu failure
Posted: Fri Jul 13, 2018 6:13 am
by patrickjburt
Has your problem been solved?
Posted: Sun Aug 04, 2019 11:55 am
by elainemartin1
I think yes, if the author didn't answer still. Anyway, her solution is rather interesting and may be even more effective than the others.
Posted: Tue Jan 28, 2020 8:21 am
by fovoykro
any solution? https://www.krogerfeedback.info i am facing same problem
