Guitar acting strange when trying to use Capture Duo
Posted: Sat May 14, 2016 9:07 pm
by jamestate4
So, I just picked up a AudioBox iTwo today so I could use it with my iPad Air(9.3.1). I'm using the iPads adaptor with the usb cable that came with the iTwo. The device has power. I plug it into my iPad and the app recognizes that it's plugged into the iTwo. I plug my guitar in directly to the first slot using a standard TS cable. I set the levels so that I see a green light on the iTwo. I can hear the guitar but I can not see that it's being played on the app. I'm also not able to record. This sucks! Am I doing something wrong? Let me know if you have any additional questions.
Thanks!
Re: Guitar acting strange when trying to use Capture Duo
Posted: Sun May 15, 2016 2:25 pm
by jamestate4
I figured it out! It makes no sense but I had to enable the microphone on the device in order for it to work correctly. Thanks!
Posted: Wed Jun 28, 2017 1:09 pm
by cristofe
That IS the solution.....and the problem. Guitars have a very low output to start with.
The problem is matching the level to what the interface wants to see. As was already
pointed out this can be done from switching from line level to mic level. BUT....a better
way to accomplish this is through the use of a direct box. You may find this article helpful:
http://www.audioadapter.net/articles/do-i-need-a-di-box
Posted: Sat Nov 16, 2019 7:34 am
by solomonmika
What's your guitar? I also have some problems.
Posted: Mon Jan 27, 2020 2:51 am
by mykfcsurvey
Welcome to the KFC Guest Experience Survey. We esteem your authentic criticism and value you setting aside the effort to finish our study. kfcsurvey
Posted: Thu Feb 20, 2020 2:01 am
by aradiralamii
Will the iPad recognize the guitar and mic as separate to apply different effects to it?
