Anyone know if:
1. You can use the iTwo with iOS versions below 7, like v6? (I know you can't use the Capture app below iOS 7). 2. You can use the iTwo on WinXP with Asio4All ? (I know you can't use the iTwo drivers on anything below Win7). Thanks! |
I cannot comment on iOS as I'm not an "i" guy.
You can use the iTwo on WinXP with Asio4All ? I theory that should work.....but Presonus does not recommend the use of ASIO4All. I know you can't use the iTwo drivers on anything below Win7 How do you know this? I know the current drivers do not say that XP is suppported but have you actually tried to install them?
Well, it does work with an iOS version lower than 7.
There is a problem in the input adjustment for the mic pre's, though. On both channels, at the end of the knobs travel, the volume takes a power jump! It's too bad the gain couldn't be distributed more evenly across the control's range. I'll check on seeing if the drivers work on Windows XP next. |
Windows XP Service Pack 3
Audiobox iTwo firmware 1.25 Simply does not work and will probably lock up your computer. Drivers do not matter... it just doesn't get to the point of interfacing with a driver. When you plug in the iTwo it just stays on "Found new Hardware". I actually had to unplug the computer because it would not shut down. Just for anyone's curiosity (as I assume it's the iTwo firmware that does not like WinXP), here are the drivers I tried to install: Latest iTwo driver (v1.3): window pops up saying "For windows 7". Last 22VSL driver that listed WinXP compatability (v1.2): locks up when plugging in iTwo. Asio4all: installs fine but it doesn't matter, iTwo doesn't connect to WinXP at all. Except for my beef with the input controls, this unit works fine on Win7 and an older iPad 2 (iOS v6.1.3). |
