I have an AudioBox iTwo, i am using windows 10 and the last version of presonus drivers. When the sound of the PC enter in repose and i start to play something again, i listen to a scratch sound everytime. Then, when sound is playing constantly or using the studioone or whatever there's no such annoying sound. In short, the problem would be a state of rest of the sound. For example with Windows notifications the same noise happens.
Can anyone help me? Thanks. |
Have you tested by changing your buffer settings in Studio One?
Did you install the latest Universal Control software which should be v3.5.2.65533 for Windows 10 64-bit in your Presonus account. |
That sounds as if the interface is switching between applications with different interface settings, e.g. system sound at 24 bits/44.1kHz and S1 at 24 bits/48kHz. An interface can't switch gracefully when the settings of the applications are different because the buffers have to be reset at every switch.
Here's the solution!
As a work around, I went into the Recording tab on the Sound Properties dialogue, went to the properties of the Line in of the Audiobox, and enabled Listen To This Device in the Listen tab. This keeps my audio device "always active" and I no longer get that pop. I have the recording level in Windows set to 0, so this doesn't introduce any noise. extracted from: viewtopic.php?f=165&t=22687 |
