Hi, when my AudioBox iOne is being used with my iPad, I want to connect via a powered USB hub, as I am also connecting other devices (a keyboard, pad controller, external SSD). I assume I should uses the USB-B "PC/MAC" port since that way the iOne can take power from the hub, rather than the iPad, is that correct? If I wasn't using the hub, I'd connect directly from the "Device" port to the iPad instead?
Many thanks.
by SwitchBack on Sun May 09, 2021 6:39 am
Hi and welcome to these forums :)
I've seen the iPad with usb hub configuration fail due to one of the connected devices (happened to be a keyboard) slowing everything down to a stutter. Where you want the power from the hub you don't want to slow communication down to the slowest device on the hub. If your setup fails then you know where to look ;)
