Hey
I used my box and recording mic M7 a couple of months without issues. But suddenly, when I record, I only hear static and the recording is really really silent (if the volume is on 1). If I put the volume up higher, it is even worse, static all over. I tried uninstalling, other USB port, etc. but it always comes back. Another mic, same issue, another mic cable and/or USB cable, same issue. I installed the Box on another pc (laptop) and there the issue is present but not that big.
It sounds like you've already eliminated most of the probable causes. Tho you did not mention if the problem occurs with a line level instrument, guitar, bass, keyboard etc. If the problem still persists with a different source, the problem may be the AudioBox itself. I would then suggest you open a support ticket and they will get you sorted out. If it's only a few months old the warranty should cover repairs if necessary.
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW, make and model of your audio interface etc....we often can't recommend a "simple fix" If you have not already done so please READ THE MANUAL!
