hello,
Since this weekend I have two synths so I want to use studio one as a sequencer with audiobox itwo. But when I put the two synths on rhe two line ins they are not stereo. When I connect one synth to the two line ins, the sound is not in stereo. I have tried different cables from different outputs. Am I doing something wrong? I hope someone can help Rudo |
You need to setup your routing properly in S1 and send your signals to STEREO audio tracks.
There are literally thousands of how-to videos for S1. Do a Google search. That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW, make and model of your audio interface etc....we often can't recommend a "simple fix" If you have not already done so please READ THE MANUALS for your interface and S1!
