So, a few months ago I purchased a Yamaha MX88. I've been using my headphones to monitor the sound while practicing piano, but wish to be able to use my ADAM A7X monitors for it as well.
I've connected the Yamaha MX88 to my Audiobox iTwo through the two Mic Line/Inst inputs, and have managed to get the sound through my monitors. However, it's in mono, which is obviously not what you want when playing piano.
How can I get the sound to stereo? This is solely for practising, and I prefer not to use any software for it, if possible.
Thank you in advance,
John
by cristofe on Tue Jun 18, 2019 4:32 pm
There are MANY videos on YouTube on how to properly set up your Audiobox.
Google is your friend.
In the meantime........ :rtfm2:
Now....that being said......we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix"
