Audio Box iTwo
Posted: Wed Apr 10, 2019 7:57 am
by jonathanwebster
Can I run just headphones from iTwo or is it necessary to hook up the monitors??
Re: Audio Box iTwo
Posted: Wed Apr 10, 2019 4:42 pm
by cristofe
Of course you can just use headphones. BUT.....it's always good to have monitors as well.
Personally, I've found that it's good to have multiple monitoring sources to make sure your
mixes translate well. I do use headphones but it takes time to get good at mixing with them.
AND if that's all you plan to use DON'T skimp get the phones you can afford. BTW...aside
from headphones and monitors, it's good to check your mix on your phone and/or computer
as that what most people will be listening to your music on.
