Hi. I have an Itwo and M7 mic. I am trying to sample through the mic into nnxt, redrum etc in reason. I can see and hear the mics input through the Itwo, both speakers and headphones, windows can detect the signal, reason however does not get any signal. I have followed the video tutorial in reason so I think I'm doing that bit right but can get get not signal to sample at all.
Anyone had/ solved this issue?
People on the reason forums are saying that it is not reason but driver or interface related.
by cristofe on Sun Feb 17, 2019 1:11 pm
It could be any number of things. Have you optimized your pc for audio production? Have you disabled wi-fi? Are you plugged into a USB2 or USB3 port? Did you install the drivers from the included disc? Or did you download and use the latest drivers from this site? That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix"
You may need to do a clean uninstall/re-install of the drivers. Also the iTwo and other Audiobox
interfaces must be plugged into the SAME USB port that they were installed two. You can't just
randomly switch ports.
