i wonder if it is possible to install studio one 3 on a windows tablet or even on android device? I used to record in the same room where my laptop is and i am looking for another device with no fan noise just for the recording sessions. If the answer is yes what are the minimum requirements for this windows tablet to work with studio one 3? I have audio box itwo audio interface and used to work on windows 10 x64 Any advice would be very appreciated ! thanks Joud |
Android no. And a Windows tablet must be running a FULL version of Windows not RT.
As to the minimum required specs, they are listed here: https://www.presonus.com/products/Studio-One That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix" If you have not already done so please READ THE MANUAL!
