i wonder if it is possible to install studio one 3 on a windows tablet or even on android device? I used to record in the same room where my laptop is and i am looking for another device with no fan noise just for the recording sessions.
If the answer is yes what are the minimum requirements for this windows tablet to work with studio one 3?
I have audio box itwo audio interface and used to work on windows 10 x64
Any advice would be very appreciated !
thanks
Joud
by cristofe on Sun Oct 15, 2017 8:02 pm
Android no. And a Windows tablet must be running a FULL version of Windows not RT.
As to the minimum required specs, they are listed here:
https://www.presonus.com/products/Studio-One
