Using the iTwo to capture audio into iOS via lightning cable. In iOS I get two identical channels that are the sum of both inputs rather than each input channel. If I only use one input, the level is about 25dB below where it should be, but on both channels. This happens whether I'm using the presonus capture app on iPad, or more commonly, Filmic Pro for shooting video. Even monitoring headphones comes through as dual mono.
by cristofe on Sun Jan 29, 2017 3:23 pm
You may find this tutorial helpful:
by ianbeyer on Sun Feb 05, 2017 10:23 am
Stereo mix coming out of Qu-24 board and recording with Filmic Pro on iPhone 7 plus. When I use the Presonus Capture app on an iPad, get same result. Not discrete channels but dual summed mono. It's like each input channel is panned to center and there's no way to change it.
