StudioLive AR22 how to control it from Studio one
I can't hear a play back through my headphones after I've recoded. and I can't control the level of the track from studio one. I was able to do this with the FP10 interface, but I can't do it with the AR22 I anyone could please help me I've been having this problem for months Thank you |
Hi and welcome
AFAIK the only thing on the AR mixers that can be controlled from the computer is the bitrate of the interface. Everything else (e.g. selecting usb as input source for channels 19-22) is done with the buttons on the mixer. In StudioOne the AR22 should show up as an interface with for S1 22 inputs (AR channels 1-20 plus the AR’s main mix) and 4 output channels (usb 1/2 to the super channel and usb 3/4 to channels 19/20). If S1 hasn’t done this for you already, then in I/O setup create stereo outputs for both pairs of usb output channels. Then click the little box above S1’s main fader and select the usb pair you want to use for S1’s main mix. Hope that helps |
