Hi people
i am having the following (complicated) issue: I run plugins during live shows inserted in each channel of a RM16 via multirack, running on a mac mini. This works well, but sometimes i hear a kind of digital distortion with the result of a delayed signal, about 330ms. I usually run buffer sizes around 64 samples. When i look on the meters in capture, all seems ok, but the input AND output in multirack are delayed. When i change the buffer size, everything is okay again. i can also replicate this issue using studio one as my plugin host. Running capture or not makes no difference. When i unplug and replug the firewire connection, the problem is gone for a few days, then happens again. A new cable did not solve that. Has anone experienced something like this? thx
SL1602
RM16AI Nowsonic stage router StudioOne pro2 mac book pro 2009 ipad4 db technologies DVX 10(2x), DVX8(4x) db technologies S08(2x) https://www.waves.com/r/bqvxon |
If it was not the FireWire cable, then it might be the FireWire port(s) on the option card. There has been a problem with sockets becoming loose or even being pushed inside. Just have a look at the option card (pull it out of the rack mixer) and also check the second FireWire port. The second port can still work fine while the first is having problems.
You are running more than one audio program that accesses the FireWire driver at the same time? (Capture + Multirack)
That's not supported. If you want to record and process, then use a DAW only. You may want to test this with another computer. If it's not reproducible on another system, then it's not the hardware most likely. |
Hey,
thank you for your response! i asked the question with running capture and multirack simultaneously to the support, they said it would not be an issue (capture and S1 at the same time does not work), and indeed i worked for years like this without an issue. Added to that, the problem exists with or without capture as well as running studio one as my plugin host alone. The other thing is, the audio arrives always on time in capture, and at the same time it arrives delayed in my plugin host. I tend to blame the core audio driver on my mac mini, because my macbook never failed. Hopefully the video attached demonstrates this...
SL1602
NEWS!
today i could replicate the problem with my 1602 firewire using the bad mac mini. So it is not the RM Mixer, which makes me happy. The opposite test, my RM 16 connected to my ancient mac book worked well. I think i have a mac mini for sale ![]()
SL1602
