Looking for a good Megaphone effect using FX/FAT settings for vocal Mic.
I've try some stuff but not good results.
Sample MP3 is what I'm looing for (used TC-Helicon "V")
Thanks for any suggestions (Need good detail)
Sample Megaphone.mp3
(502.1 KiB) Downloaded 91 times
SL24 s3
NSB 16.8
NSB 8.8
Dell Studio 1558 laptop, 6GB ram
Windows 7-64bit
Capture 2, iPad 2
by PreSonus Seth on Thu Mar 21, 2019 9:53 am
Use channel PEQ.
Set the High and Low bands to shelf, not peak, then use them as a band pass filter. Drop the gain on both to -6 or higher, then raise / lower the frequency on each until the signal sounds like an old speaker, or megaphone.
The idea is that you're shaping the EQ to mimic a horn style PA speaker that can only reproduce a limited frequency range (200 - 2k hz, etc).
Some compression may help as well, try the auto setting and just lower the threshold until you get around 3-6 dB (or adjust to taste).
