When I engage the GR button the led on ch.1 3 4 and 11 light up starting from the top down. What is going on ? Thanks
I think, with all due respect, you need to spend some time in the manual.
The meter options (input, output, GR, aux) give you an overview across the channels of what's going on, but in most cases you have to select a channel next to make changes. Same with the noise gate and compressor settings. When you try to change something directly from the GR meter mode, the FAT channel will temporarily switch to the FAT settings of the input or output that was last selected. In GR meter mode there is no relationship between the flashing LEDs and the knobs right below them! |
